ARP flood by Enable Connectivity Check for routing
PeterUK
edited November 2021 in Security
Is their a setting where I can disable ARP check then ping IP for Connectivity Check?
I would like to use a 5sec check period but not to ARP the gateway and use last known ARP check for the gateway.
As I have 4 routing rules and doing Connectivity Check it makes the Zywall 110 ARP every second~
Also I'm doing the same ping IP for the checks might it be better for the USG to look at all the Connectivity Checks going out the same interface and do one instead of four?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Thanks for your feedback and the behavior is by design
    When set the Policy Route with Heath Check.It send arp request before ICMP.
    No matter ping the same address or not.
    Thanks your advice.
    We will put this idea to our future development evaluation.
    Thanks you
    Kevin
