NWA210AX - How access web interface???
I just purchased my first Zyxel product, NWA210AX to see if I like it compared to the UniFi stuff. I plugged it into my switch and it connected to the net. I was able to connect to it via the Android Nebula app but when I type it's IP and try to login via a browser on the LAN the default user/pass of admin/1234 doesn't work. Is that the default info to get in to make configuration changes? TIA
Dear @though,
Welcome to Zyxel Community!
Once you have added the AP onto your Nebula Org/Site, the AP will be managed via Nebula, and the password of AP will be set to the one from Nebula Control Center > Site-wide > General settings > Local credentials > Password.
When an AP is managed by Nebula, most of the AP settings can only be configured via Nebula, it only has few options in the local GUI, like:
Here’s the URL to login to Nebula web version:
https://nebula.zyxel.com/
After logging in with your Nebula Username/password (same as Nebula App version), you should be able to see the Access Point column, then you can click it to configure your NWA210AX.
For more details, you may visit our FAQ pages.
https://community.zyxel.com/en/categories/nebula-nebula-access-point
For example, to check the AP status, you can read this article to get the detailed information:
https://community.zyxel.com/en/discussion/10343/nebula-how-to-check-the-ap-status-on-ncc#latest
Please let us know if any further question.
Regards,
Nathan
Dear @though,
Regards,
Nathan
- 603 USG FLEX H Series
- 481 News and Release
