Router model EMG2926: How to open ports
Ali2
in Home Router
Home hosting setup need open All ports in this picture. Where in my Xytel EMG2926 control panels can i do this?
My Xytel panel (French)
If there has any function you would like to config but it doesn't show on the GUI under your current access privilege, you could try to contact your local ISP they may help you to check it.
Bonjour @Ali2
There is a user guide manual for EMG2926-Q10A router at https://fccid.io/pdf.php?id=2197013
Section 14.3 talks about how to set-up Port Forwarding, under the Network->NAT part of the firmware.
Réseau -> NAT
I hope that this is helpful.
Kind regards,
Tony0
- 588 USG FLEX H Series
- 477 News and Release
