VMG4005-B50A on Deutsche Telekom 250Mbit VDSL?
ratkins
in Home Router
Hi all,
I’ve bought a VMG4005-B50A to use in bridge mode with my domestic 250Mbit 35b/supervectoring VDSL service in Germany and I’m having trouble setting it up. It syncs fine but I’m getting a PPPoE error when I try and connect. The ISP isn’t being any help.
On both the default “Bridge_ATM” and “Bridge_PTM” WAN configurations (which of these are relevant for my setup? Should I delete the other one?) I’ve set 802.1p = 0 and 802.1q = 7. Encapsulation is set to LLC/SNAP-BRIDGING and Service Category as “UBR Without PCR”.
With the LAN port plugged directly into my mac, if I try and open a PPPoE connection it thinks for a while then says, “A connection could not be established to the PPP server. Try reconnecting. If the problem continues, verify your settings and contact your administrator”. If I go to Console.app I see some output:
Note the `LCP: timeout sending Config-Requests`.
default 11:05:59.476639+0100 pppd pppd 2.4.2 (Apple version 881) started by ratkins, uid 501
default 11:05:59.476728+0100 pppd PPPoE connecting to service '' [access concentrator '']...
default 11:05:59.537379+0100 kernel PPPoE inputdata: unexpected data packet on unit = 9
default 11:05:59.541596+0100 kernel ifnet_attach: Waiting for all kernel threads created for interface ppp0 to get scheduled at least once.
default 11:05:59.541659+0100 kernel ifnet_attach: All kernel threads created for interface ppp0 have been scheduled at least once. Proceeding.
default 11:05:59.541354+0100 pppd PPPoE connection established.
default 11:05:59.542155+0100 pppd Connect: ppp0 <--> socket[34:16]
default 11:06:32.563692+0100 pppd LCP: timeout sending Config-Requests
default 11:06:32.563930+0100 pppd Connection terminated.
default 11:06:32.564666+0100 pppd PPPoE disconnecting...
default 11:06:32.564826+0100 pppd PPPoE disconnected
default 11:06:32.569849+0100 pppd Entering exit handler.
default 11:06:32.569874+0100 pppd Exiting exit handler.Note the `LCP: timeout sending Config-Requests`.
Any idea what might be going wrong? Is a standard configuration for this modem and Deutsche Telekom VDSL available?
I’m still confused about what the above problem is, but it’s working—when I plug the LAN port of the modem into my Ubiquiti ERX-SFP and let it bring up the PPPoE connection everything works fine. I’m getting > 230Mbps throughput on wired connections.1
- 441 Beta Program
- 293 Service & License
