I am Struggling to get my Zyxel VMG3625-T20A as base Station for Repeating Mode
Willem_Lab
Willem_Lab Posts: 1 image  Freshman Member
edited November 2023 in Home Router
I am currently using my Zyxel VMG3625-T20A Router. I want to set up another Router to be a "Wireless Repeater" for this router.
The settings have been done on the Repeater already, but the settings for the Zyxel I cannot get on the menu at all.
According to the "https://manual-hub.com/manuals/zyxel-vmg3625-t20a-02-pdf-manual/" manual, I have to enable the Mesh Setting on my Zyxel router. But that Setting is not under my wireless settings tab.
I am running the "V5.30(ABIE.7)H0" firmware at the moment.
Am I missing something or has it been removed or is it not supported?
  • SEJ
    SEJ Posts: 112 image  Ally Member
    Hi there
    The user manual in your post is for multiple models, some models support mesh, but some don't.
    You can check it on page 18, unfortunately, VMG3625-T20A doesn't support Mesh.
    FYI
