zyxel vmg8828-b50b
jion
hello everyone
I bought the vmg8828 modem/router from my previous provider, and now I would like to reuse it as an access point in an area not covered by my current wifi. First of all I would like to replace the provider firmware with a zyxel.
some data
Hardware: zyxel vmg8828-b05b
software: v5.13_abrf.0_b5_zyxelvmg8828-b50b_1.0
could you give me some information about it?
thank you very much
thank you very much
Hi there
If the VMG8828 was come from your previous provider, it might loaded its customized firmware which might limit some configuration and firmware.
Which means you might not able to replace the customized firmware to a Zyxel firmware.
For your reference.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 124 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
