[NEBULA] Can I export NAP settings?
KevinV
KevinV Posts: 1 image  Freshman Member
edited April 2021 in Nebula
Can anyone tell me if it's possible to export the complete settings of a site? If yes, please explain me how.
I want to have the settings in my documentation..
  • TomorrowOcean
    TomorrowOcean Posts: 60 image  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    Are you talking about the running-config on the NAP?
    I think you may access your NAP via SSH and key "show running-config".
  • Zyxel_Barney
    Zyxel_Barney Posts: 85 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hi @KevinV
    Welcome to the Nebula forum and apologies for the late reply!
    There is currently no function that allows you to download the entire settings of your Nebula site.
    But may I know why documentation of a site is necessary? Is this in case an unintentional setting was made and you need this document to trace back any mis-configurations? If so, why not use the Change Log page, instead?
    Change Log (ORGANIZATION > Monitor > Change log) details every configuration changes made in the Organization/Site.
    Also, if you expect to export the complete site settings, does this mean you will need to import complete site settings as well?
    Regards,
    Barney Gregorio
Nebula Tips & Tricks
