Comparison between Multy X and the new Multy M1
Lomprayah
Hi
Consider to buy the new M1 but do not know if this is model are better than my currently owned Multy X?
Anders
Anders
Hi @Lomprayah Anders,
Multy M1 support WiFi6, Open VPN, WPS, and web GUI to control the device.
If there is any feature you need on Multy M1, you can consider to buy a package.
Here are the spec of Multy X and Multy M1
Multy M1
https://www.zyxel.com/products_services/AX1800-WiFi6-Whole-Home-WiFi-System-Multy-M1/specifications
Multy X
https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-X/specifications
Note : Multy M1 are not compatible to Multy X, Multy X can only use with Multy X.
Multy M1 can only use with Multy M1.
Hi, thanks for the info, so buing the M1 will be an upgrade compared to X? and will be more future proof?0
Hi @Lomprayah
Thanks for the feedback.
As I mentioned Multy M1 support WiFi6, Open VPN, WPS, and web GUI to control the device.
I would say you can consider your requirement if you need wifi 6 features.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
