Shutdown function on devices with 4.65/4.70 do not work
G'day @lbocquet did you try logging into the router with ssh and trying the shutdown command?
Note that both the UI and the CLI methods do NOT POWER off the device.. but does stop the OS.- you will need to power offthe device manually .
# ssh your-adminuser@<your-zyxel-appliance-on_local_lan><br>Password: <br>Bad terminal type: "xterm-256color". Will assume vt100. <p>Router> show version</p><p>Zyxel Communications Corp.</p><p><span>image number model firmware version build date boot status </span></p><p>===============================================================================</p><p><span>1 USG40 <b>V4.70(AALA.0) </b> 2021-10-27 17:02:25 <b>Running </b> </span></p><p><span>2 USG40 V4.65(AALA.1) 2021-08-09 21:41:34 Standby</span></p>Router> <b>configure terminal </b><br>Router(config)# <b>shutdown</b>
(look below if the formatting is failing)# ssh your-adminuser@<your-zyxel-appliance-on_local_lan>Password:Bad terminal type: "xterm-256color". Will assume vt100.Router> show versionZyxel Communications Corp.image number model firmware version build date boot status===============================================================================1 USG40 V4.70(AALA.0) 2021-10-27 17:02:25 Running2 USG40 V4.65(AALA.1) 2021-08-09 21:41:34 StandbyRouter> configure terminalRouter(config)# shutdown
Give that a try . This works for us.
Warwick
Hong Kong0 -
Sorry for the delay!
It is done in webadmin directly not by a command.
I am not alone: https://community.zyxel.com/en/discussion/7923/usg110-shutdown-restart0 -
Which firmware version is working your device?
My firmware version 4.70(AAPI.0) seems without the symptom.
If symptom still exist, you can connect serial cable to collect more information for this symptom.
You can check if terminal dumps any console log after your confirmed shutdown device message.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
