HOW CAN I CHANGE MY WAN SETTINGS FROM 100M TO 1OOOM
Milo425_
Milo425_ Posts: 1 image  Freshman Member
I have a gigabit network at home and my ISP gives me 200Mbs download speed but i can only get 100M speed due to the WAN setting on my NBG6615 Router. i have just purchased this as it says it is a GIGABIT router but i can't get my fast speeds. this is on cable and 5g WIFI. i cant find the correct settings to configure this to 1000M what must or can i do?
  • DHSN
    DHSN Posts: 3 image  Freshman Member
    what abouth you cable its cat min 5e or cat6
  • DHSN
    edited January 2022
    its writing on you cable  cat5e or cat6
  • Hill
    Hill Posts: 156 image  Master Member
    What is your cable type? Some of the cat5e only support 100M.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited January 2022
    Hello @Milo425_
    The user guide for your router is available at https://download.zyxel.com/NBG6615/user_guide/NBG6615_v1.00_ed2.pdf
    What version of firmware is your router running also?
    If you connect to your router using an Ethernet cable, and then do a speedtest do you get a faster speed?
    If yes, then it could be that WiFi is slowing you down. The user guide says that WiFi with a standard 20MHz channel offers speeds upto 150 Mbps whereas a 40 MHz channel uses 2 standard channels and offers speeds upto 300 Mbps. (Table 13 section 6.4)
    I hope that this is helpful.
    Kind regards,
        Tony
