Accsess Point constantly blinks Green-Amber
Luc_mueller
Luc_mueller Posts: 1 image  Freshman Member
edited May 2024 in Wireless
I have a Problem i bought an Zyxel WAX610D and can not set it up. I used a Powercabel to connetc the Access Point with Power. Then the Acces Point stats booting but after 2-3 minutes the process starts agian from the beginning. I allready tryed a reset. does someone has a idea what tho do ?
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Luc_mueller
    Welcome to Zyxel Community!
    The LED blinks green and amber means the AP is looking for Nebula or AP Controller Management.
    There are two ports on WAX610D model, ensure plug in the Ethernet cable into the uplink port.
    If you’d like to manage AP via Nebula, the guide for your reference:
    https://community.zyxel.com/en/discussion/12452
    To run AP in standalone mode, you may download our ZON tool and use ZON to check the status of AP.
    https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
    You can connect your computer directly to the switch through cable, and using ZON to see if AP get the IP address correctly.
    You have to select the right network adapter.
    (ex: Ethernet: intel Ethernet connection and wireless: intel dual band wireless, it depends on the computer)
    Then click open Web GUI on ZON or type AP’s IP address in browser to access GUI and setup wireless network.
    Don’t hesitate to get back to us if you need any more information.
    We wish you a nice day. Thank you
    Regards,
    Bella
  • Zyxel_Bella
    Hi @Luc_mueller
    Regards,
    Bella
