NAS326, auto execute command at startup
P13r0
P13r0 Posts: 3 image  Freshman Member
Hi all,
I would like my NAS326 to execute some (simple) commands at startup, but I would prefere to keep NAS' software untouched; in other words, I would prefere not to install Tweaks/Random Tools. "Since those packages exist, the standard f/w already provides a way to execute something at startup", I guess. Assuming I'm right: which is the "magic file" (...or the "magic trick") to get the job done...?
Thank you in advance for your help!
Regards
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    The magic trick used by Tweaks and RandomTools is that they are zypgs, installed in the normal way (apart from the MetaRepository injector), and so they are started regularly by the firmware package manager.
    Fortunately for you there is another way. The packages are started by /etc/init.d/zypkg_controller.sh, and this script contains this snippet:
    [code]
    ZYPKG_PKG_SRC_PATH="/i-data/.system/zy-pkgs"
    <snip>
    USRPKG_DEPS_START="${ZYPKG_PKG_SRC_PATH}/USRPKG_DEPS_START"
    <snip>
    case "$1" in
    "start" )
    <snip>
        # - start to startup packages according to ${USRPKG_DEPS_START}
        while read zypkg; do
            bname=`basename ${zypkg}`
            zypkg=${ZYPKG_PKG_SRC_PATH}/${bname}
            Processed_Packages=${Processed_Packages}:${bname}
            write_log "- starting package \"${bname}\" ..."
            #ckeck ZYPKG_DEPS format
            CHKVERSION=`grep "/i-data/" ${zypkg}`
            if [ "$?" != "0" ]; then
                PKGVOLPATH=`grep ${bname} ${PKGSTATUSFILE} |grep "Installed-Rule" |awk -F":" '{print $2}' |sed 's/\/$//g' |sed 's/ //g'`
                zypkg=${PKGVOLPATH}/etc/init.d/${bname}
            fi
            if [ ! -x ${zypkg} ]; then
                write_log "---> Error: start-up program \"${zypkg}\" is not existed or not excutable"
            else
                ${zypkg} startup
                if [ "$?" == "0" ]; then
                    write_log "---> start \"${bname}\" successfully."
                else
                    write_log "---> start \"${bname}\" failed."
                fi
            fi
        done < ${USRPKG_DEPS_START}
    [/code]
    So basically it reads the file /i-data/.system/zy-pkgs/USRPKG_DEPS_START line by line, each line is considered to be a filename, the directory is stripped, and /i-data/.system/zy-pkgs/ put in front. If the resulting filename is executable, it is executed with 'startup' as argument.
    So create an executable script in /i-data/.system/zy-pkgs/, and put it's name in /i-data/.system/zy-pkgs/USRPKG_DEPS_START (which doesn't exist by default).
    You can also use /i-data/.system/zy-pkgs/USRPKG_DEPS_SHUTDOWN to shutdown your stuff cleanly on nas shutdown.
  • Mijzelf
    [code]
    <snip>
    <snip>
    case "$1" in
    "start" )
    <snip>
            fi
            else
                ${zypkg} startup
                else
                fi
            fi
    [/code]
  • P13r0
    Thank you so much! :)
    I'll try, and let you know the result
    Regards
  • P13r0
    ...It works, thank you again!
    Just a note, for non expert users (...like me):
    [code]
    [/code]
    The executable file (i.e. /i-data/.system/zy-pkgs/your_script.sh) MUST contain the string "/i-data/", otherwise the NAS will try to execute a file (tipically /etc/init.d/your_script.sh)... that doesn't exist.
    A simple remark (something like: # /i-data/) is OK too.
    Regards
