Plex Upgrade
hobbygirl
hobbygirl Posts: 13 image  Freshman Member
I have Plex successfully running on my NAS326. There is an upgrade to the server software. How do I install the upgrade. The file as a .spk extension. Thanks in advance.
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    When you disable Plex in the package centre, and enable it again, the webinterface will switch back to the installer page, where you can upload your new version.
