Configure the firewall from nebula
is it possible from Nebula to configure the Firewall as if you were using the local interface?
The interface seems very "poor" to me, I don't know if this depends on the free license ...
For example: if I wanted to create objects is it possible to do it from nebula?
Thanks Marcello
Dear Marcello,
there is no need to create objects as you know from Standalone.
Just enter the IP in the Firewall Rule during the configuration step.
Nebula is different from On-Premise platform, so you need to re-think your configuration, the most config is more logical and easier for you, give it a chance
Regards,
Tobias0
- 601 USG FLEX H Series
- 480 News and Release
