Is it possible to disable 2.4G for specific AP's within the same SSID?
In my use-case (concurrent operation) I do not need 2.4G for most rooms. However, there is no option to make this happen in Nebula. Setting it to the lowest 3dB seems the only way.
This is a waiste of energy and RF (beacons).
Is there another way for disabling this radio?
Thank you.
Thank you.
Hi @papu
You need to create 2 SSID one with 5GHz and one with 2,4GHz then you can use Tags to set them to dedicated AP, which should only display 5GHz or bands.
In Radio Settings you can put 2,4GHz to 1dB if you don´t want to split it.
Regards,
Tobias0
Hi @papu
Regards,
Tobias0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
