Smart Guest/VLAN network
I 'm new and need some assistance.
I have a NWA110AX i have setup different SSID'S
Now i go in the nebula center to accespoint>SSIDadvanced settings and then by VlAN ID i had the "option Smart Guest/VLAN network tip, click here" but this is gone, now how to change dhcp iff it's gone and you can only set it up ones?
Thanks for the help
Thanks for the help
Hi @MenomenicIn the "SSID Advanced Settings" page , you can scroll down the page and find the VLAN ID settings.
By default the vlan is "1", so there's no additional setting needed
Only when you set a different VLAN ID on the column, the NCC will display the smart VLAN setting you've mentioned.
Click the hyperlink, you can configure the gateway settings on NCC.
Best Regards,Richard0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
