Forgot my login/password on the mobile app zCloud!
Flinta
Posts: 4 Freshman Member
Anyone can help how i can recover that?
Thx
#NAS_June
If the account is admin, that you can use HW reset button with 1 beep and release to reset the password back to "1234", but the acount is normal account, you can use admin to modify the password directly.0
Thank you for the answer ljnrsi..nut that is for the NAS login..not for the ZCLOUD APP!0
zCloud APP is using NAS's login password to access, so it can work for you.
Have you tried it before?0 -
does anyone know what the username and password should be when you first login to the zcloud app and it finds your device by IP and then it asks for username and password, I try the one that I use to login and it says invalid.0
As I know, need to login NAS firstly, set up the username and password, after that, you can login zcloud app with the username and password.
I'll suggest to use Zyxel drive app, it use Pcloud server account to login.0
- 415 Beta Program
- 2.4K Nebula
- 147 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 262 USG FLEX H Series
- 271 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
