Which LTE/5g modems/routers supports flawless bridge mode/passthrough
bonne
bonne Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
I live in a location with no decent cabled internet, so I am looking at a 4g/5g solution as this should give me a decent speed over my cabled alternatives
But I need an unfiltered, 100% bridge/passthrough solution where this ISP public IP passes through un-NAT'ed to my internal firewall.
I found the Zyxel LTE5388-M804
Will this also allow setting up your own APN (in order to get static IP address)
Or are there any better Zyxel 4g/5g solutions, that can do this? Or other products than Netgear?
Regards, Lars
  • bonne
    I bought it... and it works in bridge mode
  • bonne
  • ngervasi
    ngervasi Posts: 9 image  Freshman Member
    Also NR7101 works in passthrough mode.
