NAS542 showing wrong size for HDD
Tokeloshe
Tokeloshe Posts: 1 image  Freshman Member
Hey all,
I could use some help; I have a NAS542, with 4 HDDs on it (not on RAID but as simple / basic volumes); I have attached photo for this; my problem: it seems that volume 4 is somehow "merged" with volume 2; none of the HDDs are full (as I check the size on them - WinSCP); is there a way to solve this issue?
Many thanks in advance for any idea / support!
  • Dexter
    Dexter Posts: 108 image  Ally Member
    You can check the share folders.
    And check if the folder is set up correctly on the right location.
