NAS326 - Transmission
ak_simoN
Hello, I have a problem with Transmission. I have version 2.84zypkg002.
Is it possible to have newer version?
I want to set a password but i can't open, edit or copy transmission settings file even if Transmission is disabled
Could you share the screenshot of which steps do you stock on it?0
You need to login as root to have permission to edit that file. Make sure transmission is not running.
I login as a root and I can change settings file but it looks like I have two folders with Transmission config files. I will change both of them but how to set up password to log in to transmission WebGUI from WAN0
- 588 USG FLEX H Series
- 477 News and Release
