Zyxel vs Nebula.
SELBERG
Hello!
What is the difference between Zyxel NR7101 and Nebula NR7101?🤔
Hi Sir,
The mainly difference on these devices is, the Nebula NR7101 can be registered and managed by our Cloud Platform - Nebula Control Center. Where you can easily manage/maintain your network with the benefits below:- Monitor your network at any place, such as checking cellular signal quality, check connected client number, and other device information
- Devices will auto-upgrade it's firmware to the latest version when available (you can also schedule a time for device to upgrade firmware)
- If there's any connection issue happened on device's WAN connction, NCC can auto-alert the user through mail. So you can troubleshoot the issue as soon as possible (maybe caused by loosen cable, or ISP network issue.)
- Since the Nebula NR7101 includes a bundled 1-year PRO pack licenses, so all above services are free in 365 days after you registered on the Nebula!
Best Regards,
Richard
Hi Sir,
Best Regards,
Richard
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
