Impossible de désactiver le réseau invité
Hi Sir,
Sorry for causing your inconvenience, could you please enable the Zyxel Support in the directory [Help (bottom-left of NCC) >Support Request > Invite Zyxel support as administrator > Save] and Provide your Org/Site name for us for further investigate in your case?
Best Regards,
Richard0 -
Bonjour C'est fait,
L'organisation : ETELYS
Le site concerné : LYCEE HOTELIER
Merci par avance.0 -
Hi Sir,
We've confirmed this issue, and will fix this as soon as possible.
The reason of the case is, all APs registered in this site are NWA50AXs, so NCC grey out some settings that aren't supported by the AP. But actually the guest network should be enabled (since the AP should have the capability according to the device function table), so we'll fix the case soon.
Sorry again for causing your inconvenience.
Best Regards,
Richard0 -
Ok bien noté,
Merci de m'avertir lorsque cela sera corrigé
Cdt0 -
Hi Sir,
The issue has been fixed.
Best Regards,
Richard0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
