EMG3525-T50B Firmware
FSchlechter
FSchlechter Posts: 1 image  Freshman Member
edited January 2022 in Home Router
I have purchased an EMG3525-T50B from the local computer store, however the router seem to be causing issues:
1. 5G Wifi not always working and need several restarts before coming up.
2. DNS intermittently stop resolving for 30 - 90 seconds.
3. External USB drive share sometimes stop working and require several modem restarts and power off's before coming back.
I have searched the internet and can not find any firmware updates, according to this forum i should get a firmware from the service provider that supplied the modem, in this case it is a computer store and they already suggested that i look at the manufacturer support site for firmware downloads.
Please advise on where i can download the most recent firmware, current firmware seem to be the initial release version.
  • YeK
    YeK Posts: 150 image  Master Member
    Hi
    Can you please provide the serial number of this device? You can find it on back label of device.
  • Etherion
    Etherion Posts: 1 image  Freshman Member
    I have the same issues with my EMG3525-T50B Serial number S210Y19030583. Firmware Version
    V5.50(ABPM.2)H0
    I can't seem to find any updated firmware searching and I can't add the device to my Zyxel
  • robwheddon
    robwheddon Posts: 1 image  Freshman Member
    I have your router
    • Model Name
    • EMG3525-T50B
    • Serial number
    • S190Y50097008
    • Firmware Version
    • V5.50(ABPM.2)H0
    • The 2.4 and 5g Wifi stopped broadcasting although it indicates it is on,
    • You have not made any firmware available for this device and my service provider refers me to your library.
    • Please assist me with updated firmware, the device is not functioningnas advertised.
    Regards
  • Inkfity
    Inkfity Posts: 1 image  Freshman Member
    anyone with fairmware link to zyxel
    EMG3525-T50B router
  • blessmusa
    blessmusa Posts: 1 image  Freshman Member
    Can I please have link to
    EMG3525-T50B router firmware.  The router keep disconnecting
  • YeK
    Etherionrobwheddon
    The fw version of your device is customized version, please contact with your service provider for help.
  • YeK
    Inkfityblessmusa
    Please provide current fw version of your device.
  • wtshwale
    wtshwale Posts: 1 image  Freshman Member
    why are still using this routers if they dont provide firmware. we have other option in the market. they dont even reply the comments.
  • Antonhdt
    Antonhdt Posts: 1 image  Freshman Member
    I have the same issue , whats the latest on this ?
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @Antonhdt
    Welcome to the forum.
    What firmware have you got installed?
    If it has ABPM in its name, then the V5.50(ABPM.6)C0 linked from the following post might help you.
    The firmware is based on OpenWRT, see https://openwrt.org/toh/zyxel/vmg8623-t50b
    Kind regards,
    Tony
