Ping is not stable, packet loss, bad performance, sometimes router stuck
-Worst ping is very high and not stable as should
-Packet loss
-Sometimes web page of router is unreachable via LAN and router need to be rebooted for fix
What I can do with that?
Hi @tak3joy
Welcome to Zyxel Forum.
Could you provide your network topology?
Please use cmd.exe on the computer ping the IP address (3.70.76.47) or the Domain name(lanet.ua).
Is there any packet loss of the result on cmd.exe?
We try with client connected with ethernet cable or wifi, it should not have a packet loss.
Ping made from my computer connected to router with cable. Sort of, I solved the problem of resetting the router to factory settings and completely configuring it from scratch. I have 13 devices on my home network, these are TVs, TV box, Laptops, Smart Power Plugs, Phones, Security Cameras, NAS, etc., nothing unusual. I'm talking about the fact that it's not normal when the ping of 5 meters of the cable reaches even 10ms to the router, I have my old routers and there are no such problems, of which Linksys, MikroTik, Asus. But even after resetting the settings, I have a ping of 30+.lanet.ua - is my local internet provider3.70.76.47 - is the Amazon server in Frankfurt0
So on rebooting the router you get no Packet loss from the router?
last time I used winWTR it acks like a ping flood which the router may delay the ping
use winWTR 0.91 is better
Hi @tak3joy,
Are you using cat5, cat5e or cat6 ethernet cable?
May I know which port are you connected to when doing the test (from left to right (P1-P4) )?
Can you try with other port on NBG6818, does the symptom still the same? Or it only happen on the specific port?
Can you also try with other client connected to Armor G1? Does the symptom still the same?
I 'am using CAT5e cable connected to P1(LAN1) cable length ~5meters, absolutely same situation on all ports. Problem was fixed(I hope, but it hasn't happened again yet) with FACTORY RESET.
I assume that the router updates that were earlier could affect the stability and there may have been installation errors, if only I could find out the password from the archive with full logs.
I also tried WinMTR 0.91 and didn’t notice any difference, the maximum ping is still 39, but the average is 0 because the problem is no longer critical, I will continue to investigate this and hope for a comprehensive solution to the problem.
That is the router replying to a low TTL ping to host but its possible the router is coded to delay such requests.
To really test the router forwarding packets you need to do something like is:
HTTP server 10.0.0.3 PC to WAN of the router with static IP 10.0.0.2/255.255.255.0
LAN 192.168.1.1/255.255.255.0 with PC to LAN 192.168.1.2 then use tcping64 to ping the HTTP server
tcping64 -t 10.0.0.3
https://download.elifulkerson.com/files/tcping/0.39/x64/
Now I would not expect a high ping in this setup
Here is my DHCP Settings:
And results are 192.168.123.2-192.168.123.40 has no response, like on screenshot above:
And here 192.168.123.1 I see that ping 26ms:
you need to ping from LAN to WAN not to LAN gateway0
I made ping from Laptop Lenovo ThinkPad X240 with LAN cable to Port 4 length ~10 centimeters, and result is:Zyxel_Jerry said:Hi @tak3joy,
Ping from Raspberry Pi B+ with LAN cable to Port 3 length ~20 centimeters, same result:
- 588 USG FLEX H Series
- 477 News and Release
