Nas326 Twonky Server broken after firmware update.
SarahJH
So my Twonky server no longer works.
It's on, but the web address no longer works.
And my Smart TVs show no files being shared.
It worked perfectly before the firmware update (5.21.10), there appears to be no way to rollback the firmware. Nothing else on my system has changed.
Can it be fixed, or do I throw my NAS326 away and buy a Synology in it's place?
Are you able to open the browser 192.168.1.3:9001 on the browser with incognito web page ?
You can also check the config on the NAS326, use telnet to login NAS and access as root user to
check the command below
cat /ram_bin/usr/local/dmsf/conf/twonkyserver.ini
In the file the http port should stay the same in 9001# HTTP Server Porthttpport=90010
Enable/untick enable/apply/reset make no difference to the Twonky status and setting address ....... this site cannot be reached. Twonky server on my NAS310 (192.168.1.23:9001) works perfectly so it's not a router problem, it's a Twonky on the NAS326 problem.0
In the file the http port should stay the same in 9001# HTTP Server Porthttpport=90010 -
Using WinSCP I logged into the NAS ........ twonkyserver.ini hadDexter said:Are you able to open the browser 192.168.1.3:9001 on the browser with incognito web page ?
In the file the http port should stay the same in 9001# HTTP Server Porthttpport=9001# Port of the http server
httpport=
Which I edited to# Port of the http serverhttpport=9001
Still can't access the page ............. incognito also the same.
No Wait ........... unticked the 'enable Twonky server' box.
Hit 'apply'
Hit 'apply'.
Hit 'status and setting' 192.168.1.3:9001
AND ........
Thanks, you fixed it!!!!!!!!!!!!!!!!!!!!!!0 -
May I know which firmware are you using before upgrading the firmware to the latest one?
As I upgrade frimware from the previous one V5.21 AAZF.9, I do not meet the issue0 -
Hi, could you please help how to set the WinSCP? I am not successful how to log.SarahJH said:
httpport=
Hit 'apply'
Hit 'apply'.
AND ........
Use WINSCP, need to select SFTP protocol,the account and password are the same as the settings on the NAS, you can change the account as root user to login with WinSCP.0
I have the same problem with my nas326
I think that after some sudden power cuts the entire twonky program was corrupted, I can no longer find any trace of it!Http server port is already 9001
what could have happened?
Thank you all !!!Neo
Hi. Did u manage to get it fixed? I have the same issue after a power failure.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
