EMG3525-T50B Firmware
FSchlechter
I have purchased an EMG3525-T50B from the local computer store, however the router seem to be causing issues:
1. 5G Wifi not always working and need several restarts before coming up.
2. DNS intermittently stop resolving for 30 - 90 seconds.
3. External USB drive share sometimes stop working and require several modem restarts and power off's before coming back.
I have searched the internet and can not find any firmware updates, according to this forum i should get a firmware from the service provider that supplied the modem, in this case it is a computer store and they already suggested that i look at the manufacturer support site for firmware downloads.
Please advise on where i can download the most recent firmware, current firmware seem to be the initial release version.
Hi
Can you please provide the serial number of this device? You can find it on back label of device.
I have the same issues with my EMG3525-T50B Serial number S210Y19030583. Firmware VersionV5.50(ABPM.2)H0
I can't seem to find any updated firmware searching and I can't add the device to my Zyxel0 -
I have your router- Model Name
- EMG3525-T50B
- Serial number
- S190Y50097008
- Firmware Version
- V5.50(ABPM.2)H0
- The 2.4 and 5g Wifi stopped broadcasting although it indicates it is on,
- You have not made any firmware available for this device and my service provider refers me to your library.
- Please assist me with updated firmware, the device is not functioningnas advertised.
anyone with fairmware link to zyxel
EMG3525-T50B router
Can I please have link to
EMG3525-T50B router firmware. The router keep disconnecting
The fw version of your device is customized version, please contact with your service provider for help.
why are still using this routers if they dont provide firmware. we have other option in the market. they dont even reply the comments.0
I have the same issue , whats the latest on this ?
Hello @Antonhdt
Welcome to the forum.
What firmware have you got installed?
If it has ABPM in its name, then the V5.50(ABPM.6)C0 linked from the following post might help you.
The firmware is based on OpenWRT, see
Kind regards,
Tony
- 441 Beta Program
- 292 Service & License
