Disable 5ghz on multy U
Mkko82
Mkko82 Posts: 2 image  Freshman Member
edited March 2022 in Multy WiFi System
Is it possible to do radio management on a multy wifi system?
I have 3 x WSR30 Multy U access points and they are great, but i would like to disable the 5ghz radio on some of them.
I think this is pretty basic feature and most competing mesh systems allows this level of management, so was quite surprised not to find it anywhere?
Strangely the multy app "advanced" menu is empty, so was thinking could it be just an error on my app? I am in bridge mode, so that also might cause the empty menu, as it did state some features are not available on bridge mode...
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Mkko82
    Thanks for your valuable suggestion. We'll evaluate the feature.
    Yes, there are some features in advanced pages on the app, since you're in bridge mode, the features are not able to used in bridge mode.
