USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
  • UPMI
    UPMI Posts: 1  Freshman Member
    @Zyxel_Stanley Can you please send me the firmware as well. My connection is dropping daily.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    edited July 2018
    I will send you the firmware by private message.
    Please has a check. :)
  • thom_ko
    thom_ko Posts: 16  Freshman Member
    @Zyxel_Stanley The new firmware works absolutely fine. No problems at all. I'm going to mark the case as solved.
    But one point still is remaining: In which official release will this issue be fixed? As a test I installed the recently released version 4.32 and had the same problems as I initially described. By the amount of feedback you get it seems that I'm not the only one having such problems.
  • link000
    link000 Posts: 39  Freshman Member
    Hi @link000
    A brief report on the firmware:
    1. Wi-Fi is stable.
    Of the minuses:
    1. Immediately evident is the lack of textual information that the new firmware has been released. This occurs when you log on to the web interface through IE 11.
    2. The empty diagnostic tab when using IE 11.
  • Zyxel_Stanley
    edited July 2018
    Hi @thom_ko
    This fix was not merged into ZLD 4.32 yet.
    If users encounter certain issues, please help to contact our Zyxel local representative for technical support or just drop a message on the forum.
  • moonmoth
    moonmoth Posts: 16  Freshman Member
    Hi , @Zyxel_Stanley, I have installed the firmware that you sent me but we are still having problems with the wi-fi dropping. Its gone down at least three times today so far. We only have 6 staff using wifi so it should be stable. Here are the device settings.
    The firmware is showing as 4.31 with an extra tag on the end. Does this correct to you?
    Moonmoth
  • Zyxel_Stanley
    Hi @moonmoth
     I will send you private message for check this issue more detail.
  • link000
    link000 said:
    Hi @link000
    1. Wi-Fi is stable.
    Of the minuses:
    Early I was overjoyed. After the next reboot, Wi-Fi did not work. I had to deactivate the access point profile again, and then activate it again. Wi-Fi earned, but after a few hours again disappeared. I'm sad. :/
  • Zyxel_Stanley
    Hi @link000
  • Zyxel_Stanley
    Per our discussion, the issue is coming from WiFi outgoing interface is setup as LAN2. But LAN2 interface not binding on any physical port. It caused client unable receiving IP address after connected to WiFi.
    There are 2 ways resolve this situation.
    (1) Change outgoing interface as LAN1 in SSID profile.
    (2) Change port group setting. (at lest 1 port is binding on LAN2 interface)
