Help | XMG3927 - Port Forwarding | DMZ not Working
poolk
Today i switched to the XMG3927 G.Fast Router to leave the ISP Provided Modem behind (Switzerland - Wingo / Swisscom.
My Setup is simple:
WAN - XMG3927 - LAN (With Nextcloud-Server)
Situation:
WAN Works perfectly and normal routing is fine.
As you can see, i would like to reach my Nextcloud from outside via Port-Forwarding on Port 80 and 443.
(DynDNS is seperate, i'm testing with my public ip)
My Nextcloud is 192.168.0.47 an it works when i access this ip internally.
Problem:
From outside i can't reach anything.
A portscan to my public ip from outside shows all Ports filtered / closed.
What am i missing here?
Thank for any help!
Port-Forwarding settings for http (https is the same just 443):
Static IP for Nextcloud:
My Setup is simple:
Situation:
Problem:
Thank for any help!
It's working now and i have no clue why.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
