How do 2 SIM work in NR7101?
ngervasi
ngervasi Posts: 9 image  Freshman Member
edited January 2024 in Mobile Broadband
In the manual there is no reference about dual SIM support.
How does it work? Can both SIM be used simultaneously? Or there is some sort of failover? Can I create 2 bridges, one per SIM to the same LAN interface?
«1
  • Pino
    Pino Posts: 1 image  Freshman Member
    I need the same info, anybody?
  • ngervasi
    Since nobody answered, where can I find the official support center for NR7101?
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
  • ngervasi
    Thanks Tony, unfortunately there's nothing there related to dual SIM support.
  • GiulioT
    GiulioT Posts: 2 image  Freshman Member
    Hi, I was searching for the same info, there's no mention anywhere so far from my investigations. Did you find something meanwhile?
  • ngervasi
    No, unfortunately not. Anyone?
  • SELBERG
    SELBERG Posts: 375 image  Master Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    I have tried 2 sims with Swedish Telia and Swedish Tele2.
    Could not connect to second sim, changed place but still the same.
    Made this test with ABUV4 not latest firmware ABUV5.
  • Blackbird
    Blackbird Posts: 8 image  Freshman Member
    First Anniversary
    I am also looking for more information of this dual SIM feature. There ist nothing documented in the Manual or in the FAQ...
  • Blackbird
    First Anniversary
    In the meantime, I have received the latest information from Zyxel (in german):
    Aktuell kann nur eine SIM Karte verwendet werden. Es soll jedoch in der nächsten Zeit eine neue Firmware erscheinen, bei welcher die zweite SIM Karte für Fail-Over Zwecke verwendet werden kann. Load-Balancing ist nicht geplant und auch eine Steuerung über die Zyxel Air APP nicht.
    So NR7101 doesn't really seem to be fully developed and doesn't yet conform to the official specification. See here: Link
    ...Der NR7101 verfügt über zwei SIM-Karten-Slots, um Unterbrechungen des Netzwerks zu verhindern und einen unterbrechungsfreien Netzwerkzugang zu ermöglichen. ...
  • tonygibbs16
    The Zyxel response translates as
    "Currently only one SIM card can be used. However, a new firmware is to be released in the near future, in which the second SIM card can be used for fail-over purposes. Load balancing is not planned, nor is control via the Zyxel Air APP."
    So I guess that there is some incremental Agile or Scrum software development going on, where the hardware has been installed for the end goal, but the software has not got there yet.
    Cheers,
        Tony
