https login homepage not working
After setting up SSL VPN on the Zyxel USG50, the device seem to be working fine. I can use the internet, SSL VPN is working from the internet.
I'm now no longer able to get to the login page. Does anyone know how to get back to the router admin page?
Hi @DannyC,
It could be related to BITDEFENDER.
Please go to Web Protection and disable Scan SSL.
Go to Protection -- Online threat prevention -- settings --- web protection --- disable scan SSL
I am trying to do this also and getting the same response.0
Hi @DannyC,
Please try to ssh to device and hit following CLI to check if both service are enable.
Router> show ip http server status
Router> show ip http server secure status
I dont have BitDefender on the computerZyxel_Cooldia said:Hi @DannyC,
BrownB said:Probably the most common cause of not being able to log in to a website is using the wrong password. At least websites will be pretty clear about this problem and give you a nice Incorrect password style error message. Lets explore the reasons why you might be told that you're using the wrong password.
No, not password issue. I have the password and I even reset the device to factory password to 1234. I can SSH to the device.0 -
Router> show ip http server secure statusHere are the output:Router# show ip http server statusactive : yescontent-compression : noport : 80authentication method: defaultadmin service control:No. Zone Address Action===============================================================================user service control:No. Zone Address Action===============================================================================Router#Router# show ip http server secure statusactive : yesport : 443certificate : defaultforce redirect : yesauthentication client: noanti beast attack : nostrong cipher suite : nocipher suite : aes 3des des rc4sslv3 support : noadmin service control:No. Zone Address Action===============================================================================user service control:No. Zone Address Action===============================================================================Router#0 -
I already factory default the device. Still the same error.Fred_77 said:Hi @DannyC
some ideas...
Maybe you have changed the port in WWW menu?
Did you define an allowed IP list in WAN (or LAN) to Device Security Policy?
When SSL is connected can you see the login page? (if SSL to Device is allowed)
I can SSH to the device and view the config but not sure how to enable https back to normal.0
- 588 USG FLEX H Series
- 476 News and Release
