USG40 two factor authentication with Google Authenticator
copossum
copossum Posts: 14 image  Freshman Member
I have a USG40, FW Version is 4.70.
I have two factor authentication for admin access enabled using google authenticator.
I want to do the same for vpn users, so I followed this guide:  https://community.zyxel.com/en/discussion/12505/how-to-use-two-factor-with-google-authenticator-for-vpn-access
The problem is that when I enable 2FA for a non-admin user, I only have SMS and Email as second factors.
In Object->Auth Method->VPN Access delivery settings it is the same: only SMS and Email are available in the delivery settings.
Question: is it possible to use two factor authentication with Google Authenticator for VPN Access on a USG40?
thanks
  • Zyxel_Emily
    edited March 2022 Answer ✓
    2FA VPN access using Google Authenticator is supported in firmware 5.20 C0 and later versions. (USG FLEX/ATP/VPN series)
    USG40 doesn't support Google Authenticator 2FA authentication for VPN access. Only SMS and Email are supported.
  • MikeForshock
    MikeForshock Posts: 60 image  Ally Member
    Forced update to a USG FLEX 100 (USG 40 v2)...
  • Zyxel_Emily
