USG40 two factor authentication with Google Authenticator
I have a USG40, FW Version is 4.70.
I have two factor authentication for admin access enabled using google authenticator.
I want to do the same for vpn users, so I followed this guide: https://community.zyxel.com/en/discussion/12505/how-to-use-two-factor-with-google-authenticator-for-vpn-access
The problem is that when I enable 2FA for a non-admin user, I only have SMS and Email as second factors.
In Object->Auth Method->VPN Access delivery settings it is the same: only SMS and Email are available in the delivery settings.
Question: is it possible to use two factor authentication with Google Authenticator for VPN Access on a USG40?
thanks
thanks
Hi @copossum,2FA VPN access using Google Authenticator is supported in firmware 5.20 C0 and later versions. (USG FLEX/ATP/VPN series)USG40 doesn't support Google Authenticator 2FA authentication for VPN access. Only SMS and Email are supported.
Forced update to a USG FLEX 100 (USG 40 v2)...0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
