NAS326 - CPU Stuck at 100%
starostkadk
Hello
Im starting to see an issue, where the CPU on the NAS constantly is on 100%. If I SSH to the box its not an application which is using all the power but Software IRQ.
The only way, I have found to resolve this, is to cut the power for the NAS, and then it runs fine for some time.
I have installed the tweak package and disabled everything, except SMB.
The only package running is Transmission.
Anyone else seeing this behavior, or have a fix ?
Does executingcat /proc/interruptsa few times give any info on which irq is causing it?0
Could it be a bug in the ARM driver ?0 -
Are you uploading or downloading lots of files at the same time?
Or there is some IP address conflict in your environment?
I think it might cause by there being too many packet queues on the NAS.
A single screenshot doesn't say much. The idea is to see how fast the numbers change.Could it be a bug in the ARM driver ?No such thing exists. ARM is a platform, and so the whole OS 'talks' ARM. Further, if it is a bug somewhere, it has to be triggered by an external event, which is (more or less) unique for your box, else all 326's running the same firmware would have this problem.0
Here I ran the command 3 times quickly after eachother.0 -
ikubuf said:Are you uploading or downloading lots of files at the same time?
I think it might cause by there being too many packet queues on the NAS.0 -
The change in count doesn't look strange, given that it's busy with disk&network. So either the soft interrupts don't show up in this list, or the problem requests take a lot more CPU cycles than they should do.I see one strange thing, the mmc interrupt count is incrementing. As I assume that you are not using it right now, that is strange. Do you have an SD card inserted? Maybe it is defective?0
Mijzelf said:The change in count doesn't look strange, given that it's busy with disk&network. So either the soft interrupts don't show up in this list, or the problem requests take a lot more CPU cycles than they should do.I see one strange thing, the mmc interrupt count is incrementing. As I assume that you are not using it right now, that is strange. Do you have an SD card inserted? Maybe it is defective?0
Well, as mmc0 is the only strange behaving interrupt, try to insert an sd card and see if it helps.
I have the same problem. Please see the ss…
I do not upload or download anything.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
