[NEBULA] Error: 5G Radio Tx stuck internal reset
In the Event Log i saw the following error message for 1 of my AP's: "5G Radio Tx stuck internal reset"
After i saw a lot of these errors, i disabled 5G for my AP's, also rebooted my AP's.
I still get the error above.
What is it and what can i do about it?
Hello @Dirk
"5G Radio Tx stuck internal reset" occurs when the AP is under particular wireless environments. This issue occurs more frequently in channels between 149-165. I recommend moving the 5G Radio to a different channel.
You can manually change the 5GHz channel under AP > Configure > Radio setting.
Change the default channel (DCS) to a channel further away from 149-165. Preferably channels 36-48.
Best regards,
Barney Gregorio0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
