NR7101 Hangs on Load
Kennyblu3
i have a issue with the NR7101 Router. I am connected with Telekom in Germany with the B20 and N1 Band. I am on the newest Firmware Version V1.00(ABUV.4)C0
and the Modul Version is RG502QEAAAR11A03M4G. The Problem is the follow, under load the Router stops working. I cannot ping the router anymore , or connect to the gui. It is reproduceible with a simple speedtest. The Router will only come up again if i disconnect it from power. I have already reset the router, but it dont help. I cannot find anything in the logs.
Hi!
Latest firmware is ABUV.5, download it and try more....
https://www.dropbox.com/s/og7h04hzdb58sfh/1.00(ABUV.5)C0.zip?dl=0
i have already installed the firmware, but same issue. Is tehre maybe a new modem Version out ?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
