Entware-ng / how to fix a wget error
ariek
ariek Posts: 30 image  Freshman Member
wget: error while loading shared libraries: /usr/lib/libssl.so.1.0.0: internal error<br><div></div>
this also broke opkg update
opkg update<br>Package ldconfig version 2.27-11 has no valid architecture, ignoring.<br>Package libc version 2.27-11 has no valid architecture, ignoring.<br>Package locales version 2.27-9 has no valid architecture, ignoring.<br>Package libpthread version 2.27-11 has no valid architecture, ignoring.<br>Package librt version 2.27-11 has no valid architecture, ignoring.<br>Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz<br>wget: error while loading shared libraries: /usr/lib/libssl.so.1.0.0: internal error<br>*** Failed to download the package list from http://bin.entware.net/armv7sf-k2.6/Packages.gz<br><br>Downloading http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz<br>wget: error while loading shared libraries: /usr/lib/libssl.so.1.0.0: internal error<br>*** Failed to download the package list from http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz<br><br>Collected errors:<br>&nbsp;* opkg_download: Failed to download http://bin.entware.net/armv7sf-k2.6/Packages.gz, wget returned 127.<br>&nbsp;* opkg_download: Failed to download http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz, wget returned 127.
This error occured after I had tried to get wget to work with https (with ssl vs nossl) links.
Best Answers
  • ariek
    I have solved it by restoring wget to the wget nossl variant (default) by updating/overwriting the wget symlink.
    ln -s /opt/bin/wget-nossl wget
    This is the default state (before I messed things up) but doesn't handle https links.
    At least everything seems to work as expected.
  • ariek
    The source is Entware.
    <div>which wget</div><div>/opt/bin/wget</div><div></div>
    After removing wget from the status file (in /opt/etc/) // basically the installed apps history (opkg list-installed)
    root@NAS520:~# opkg install wget<br>Installing wget-nossl (1.21.2-1) to root...<br>Downloading http://bin.entware.net/armv7sf-k3.2/wget-nossl_1.21.2-1_armv7-3.2.ipk<br><div>Configuring wget-nossl.</div>
    With just "wget" Entware installs the no-ssl variant.
    opkg install wget-ssl<br>Installing wget-ssl (1.21.2-1) to root...<br>Downloading http://bin.entware.net/armv7sf-k3.2/wget-ssl_1.21.2-1_armv7-3.2.ipk<br>Configuring wget-ssl.<br>
    My guess, I broke something yesterday. At the moment, the "wget" command automatically uses/switches to the correct variant depending on the provided http link, wget-nossl for http:// and wget-ssl for https://
  • ariek
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    What is the source of that wget-ssl? When it's an Entware binary, it should not use /usr/lib/libssl.so, but /opt/lib/libssl.so.
  • ariek
