[NEBULA] Switches connected in a loop
That's what I what looking for.
Thanks Barney.0
Hi Levente,
Do you mean how many switches with RSTP enabled can be added into a single ring topology?
The NSW uses the default RSTP configurations and there is no way to configure this in NCC.
Max Age: 20
Hello Time: 2
Forward Delay: 15
Because of this, I recommend limiting the diameter to seven switches. So that would mean 8 switches in a single ring.
Best regards,
Barney Gregorio
Thanks Barney.0
- 588 USG FLEX H Series
- 477 News and Release
