AP firmware check failed
FerryL
FerryL Posts: 2 image  Freshman Member
Second Anniversary
edited May 2024 in Wireless
I updated my NXC5500 yesterday
since yesterday midday till today morning I got wihtin minutes following alert
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @FerryL
    Welcome to Zyxel community!
    The check status is verified successfully in our environment.
    NXC5500 uses DNS and HTTP (port80) to query firmware file from cloud server, and TCP (random port) to download firmware from server.
    (Domain is zapimg.cloud.zyxel.com)
    Please ensure NXC5500 can access cloud server to download firmware by checking firewall logs and rules.
    Thank you
    Regards,
    Bella
  • FerryL
    Second Anniversary
    I tried again to check, but the result is still not working
  • Zyxel_Bella
    Hi @FerryL
    Thanks for the information.
    We’ll need to check diagnostic file of NXC5500, can you download from MAINTENACE > Diagnostics > Controller and send the file via private message for me?
    Regards,
    Bella
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    I'd try to change the DNS server sequence.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Dear Donaldroy,
    I hope that you did some steps as we mentioned in the previous post. I also appreciate you give me the model, the firmware version you are using and what you did to make sure your DNS, firewall logs and rules are normal.
    If you did everything as we suggested, however, the firmware upgrade is still fail, please provide us diagnostic file of your AP.
    You can download from MAINTENACE > Diagnostics > Controller and send the file via private message for me. We check it as soon as possible.
    I am sorry to announce that I removed the link in your post.
    Zyxel_Judy
    Untitled Image
