Automatic Restart for LTE4506-M606
Stef
Hi All,
I need to restart automatically the Router LTE4506-M606 after a power loss
No parameter avaailable with the WebGui pages so perhaps thru a Telnet or ssh ?
Stef
Hi @Stef
Unfortunately there is no such feature over the web GUI nor the CLI interface.
The only related CLI command is “reboot”, but it works only when the LTE4506 has already been powered up.
If you have any other question regarding the LTE models, please start a new discussion from the following site.
Thank you.
Joslyn
Hi
I also need the router to automatically restart after powerloss. This is a big feature missing. Should be easy to add this functionality. Please add autorestart after powerloss!!!0 -
Hi @ColoMan1964
Thanks for your suggestion.
This forum page is related with Enterprise WLAN devices. Are you asking for Enterprise WLAN devices? If yes, could you provide which model that you use and the detail usage for the function?
However, if you are asking for the LTE models, could you start a new discussion from the following site? We separate the model series in different forum pages to ensure all the users can find the correct discussion for the model.Thanks.
Joslyn
- 441 Beta Program
- 533 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
