Can't instal NAS Starter Utility for Zyxel 540
Kazoo
Kazoo Posts: 6 image  Freshman Member
Friend Collector Third Anniversary
I just reinstaled Windows 10 on my computer, and when i downloaded the NAS Starter Utility for my Zyxel NAS 540, it can't open the installer files, so i can install the Starter Utility. What's wrong, and why can't i get this to work?
Anyone know what to do?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    edited April 2022
    Hi @Kazoo
    Can you share the screenshot related to your issue?
  • Kazoo
    Thank you for a fast reply.
    There is nothing to take a screenshot of.
    I can't get the installer of the NAS Starter Utility to start, like a normal installer does.
    After i hit enter, nothing happends.
    Whats wrong? Is it that i run Windows 10?
  • JockeSve
    JockeSve Posts: 82 image  Ally Member
    You might try installing with Admin priviledges.
  • Kazoo
    @JockeSve I have tried that multiple times, with no luck. The installer just wont start.
    Is there something that makes Windows don't want to start the installer, and where in that case?
  • ariek
    ariek Posts: 30 image  Freshman Member
    Do you really need the Starter Utility?
    Use your favorite web browser and type in the url bar: //nas540
    Or check the ip address in your router.
  • Kazoo
    @ariek I need the Starter Utility as its easier for my part, and i now realy want to know why i can't get the installer for the Starter Utility to work.
    Typing that in the url bar did nothing for me i'm afraid..
  • tonygibbs16
    tonygibbs16 Posts: 977 image  Guru Member
    Hello @K@Kazoo
    Maybe the Windows compatibility troubleshooter for Windows 10 could help get the installer to run, see https://support.microsoft.com/en-us/windows/make-older-apps-or-programs-compatible-with-windows-10-783d6dd7-b439-bdb0-0490-54eea0f45938
    Kind regards,
         Tony
  • Kazoo
    This did not either help im afraid
