NWA50AX Repeater/Range Extender (Smart Mesh?)
2»
  • PEACEkeeper
    PEACEkeeper Posts: 29
    image  Freshman Member
    Hi @Zyxel_Bella
    thank you for your explanation.
    unfortunately the AP is requesting an IP with one of the wireless interface MACs when it’s acting as repeater.
    Therefor, I have to handle them in the DHCP.
    is there a way to avoid this behavior?
    Regards,
    Frank
  • PEACEkeeper
    edited April 2022
    Deleted because of duplicate content.
    sorry for this
  • PEACEkeeper
    Hi @Zyxel_Bella
    I've solved my problem, bit I'm not very happy with the solution:
    1. a new (management) VLAN for the Zyxel APs was created
    2. the firewall rules to allow access to the Nebula cloud where adjusted for the new network
    3. all Zyxel APs where reconfigured to use these new VLAN
    4. the APs get assigned an IP address from the new network
    From now on, the MAC address doesn't matter.
    But I can confirm, that the AP which is acting as a repeater requests the IP using the MAC of the wireless interface.
    Regards,
    Frank
  • Zyxel_Bella
    Zyxel_Bella Posts: 605
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    image  Zyxel Employee
    Hi @PEACEkeeper
    Thanks for your valuable feedback.
    Because smart mesh must use wireless interface to communicate between APs, state change in the progress is necessary.
    For the last part you mentioned, we’ll do the reproduce test to reconfirm and update and result here.
    Regards,
    Bella
  • Zyxel_Bella
    Hi @PEACEkeeper
    After testing and clarifying the spec, it was confirmed that the behavior of smart mesh is to change the MAC addr to interface with the numerically lowest MAC addr due to smart mesh must use wireless interface to communicate between APs, state change in the progress is necessary.
    We’ll keep enhance the information delivering to user especially the scenario like yours. Thanks again for your valuable feedback.
    Regards,
    Bella
Nebula Tips & Tricks
