VPN clients cannot see each other
martin88
martin88 Posts: 2 image  Freshman Member
I have a security gateway (NSG100) configured as L2TP VPN server.
Client VPN subnet is 10.255.254.0/24.
There are two VPN clients:
VPN client 1 - 10.255.254.1
VPN client 2 - 10.255.254.2
Everything is working great except one thing. My VPN clients can't ping (trace, ssh, ...) each other.
Do I need some additional configuration?
Thank you.
    PeterUK Posts: 4,411 image  Guru Member
    edited April 2022
    Maybe you need a firewall zone rule for from L2TP VPN to L2TP VPN
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    @martin88
    Did you configure any security policy or routing policy? Since the NSG default setting does not block the L2TP traffic to each other.
    Can you confirm if the client firewall blocks it.
  • martin88
    I didn't configure any security policy or policy route.
    I disabled client's firewall. Ping from internal LAN is working but still not between VPN clients.
Nebula Tips & Tricks
