MyZyxel Missing Devices
Resolvtech
Resolvtech Posts: 3 image  Freshman Member
First Anniversary
I need your help because the devices we have registered have disappeared from the myZyxel portal.
In the portal they do not appear when selecting "Device Management". However, if we want to "Register the device", the portal says "The device has already been registered.".
Thank you for your help
  • Resolvtech
    First Anniversary
    I apologize. problem solved.
    Devices were on two different accounts
  • Resolvtech
    First Anniversary
    Not all but some devices
  • Resolvtech
    First Anniversary
