NAS326, Raid Array is gone
awasen
I did a disk swap on my NAS326 and then let it recreate the array (data is safely backed up) but something has gone wrong.
I can see the attached USB disk in file manager but when I log in I get a warning window that the volume is down and when I click OK it tries to open the Storage Manager but it just gets stuck spinning and the Storage Manager never shows...
How can I recreate the RAID through CLI?
Data is no issue, the disks are empty. A 2TB USB disk is attached.
I noticed that these commands where asked for from several with disk problems:
~ $ cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid6] [raid5] [raid4]
md3 : active raid1 sda3[0]
7809895232 blocks super 1.2 [1/1] [U]
md2 : inactive sdc3[2](S)
7809895424 blocks super 1.2
md1 : active raid1 sda2[3](F) sdc2[2]
1998784 blocks super 1.2 [2/1] [U_]
md0 : active raid1 sda1[3](F) sdc1[2]
1997760 blocks super 1.2 [2/1] [U_]
unused devices: <none>
~ $ cat /proc/partitions
major minor #blocks name
7 0 144384 loop0
31 0 2048 mtdblock0
31 1 2048 mtdblock1
31 2 10240 mtdblock2
31 3 15360 mtdblock3
31 4 108544 mtdblock4
31 5 15360 mtdblock5
31 6 108544 mtdblock6
8 0 7814026584 sda
8 1 1998848 sda1
8 2 1999872 sda2
8 3 7810026496 sda3
8 16 1953514584 sdb
8 17 1998848 sdb1
8 18 1999872 sdb2
8 19 1949513728 sdb3
8 32 7814026584 sdc
8 33 1998848 sdc1
8 34 1999872 sdc2
8 35 7810026496 sdc3
9 0 1997760 md0
9 1 1998784 md1
9 3 7809895232 md3
~ $ cat /proc/mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,relatime 0 0
/sys /sys sysfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
ubi4:ubi_rootfs1 /firmware/mnt/nand ubifs ro,relatime 0 0
/dev/md0 /firmware/mnt/sysdisk ext4 ro,relatime,data=ordered 0 0
/dev/loop0 /ram_bin ext2 ro,relatime 0 0
/dev/loop0 /usr ext2 ro,relatime 0 0
/dev/loop0 /lib/security ext2 ro,relatime 0 0
/dev/loop0 /lib/modules ext2 ro,relatime 0 0
/dev/loop0 /lib/locale ext2 ro,relatime 0 0
/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
ubi2:ubi_config /etc/zyxel ubifs rw,relatime 0 0
/dev/sdb3 /e-data/b4fa2cb18c2f5d504382573ffc0d02b1 fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
~ # mdadm --examine /dev/sd[ab]3
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : dbcfc7cd:54ba8c26:de73660d:fe581665
Name : NAS:3 (local to host NAS)
Creation Time : Wed May 4 20:13:45 2022
Raid Level : raid1
Raid Devices : 1
Avail Dev Size : 15619790848 (7448.10 GiB 7997.33 GB)
Array Size : 7809895232 (7448.10 GiB 7997.33 GB)
Used Dev Size : 15619790464 (7448.10 GiB 7997.33 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 4b173a40:1b7baed4:17fe2fa6:4a545d21
Update Time : Wed May 4 20:21:23 2022
Checksum : 31749dc6 - correct
Events : 2
Device Role : Active device 0
Array State : A ('A' == active, '.' == missing)
/dev/sdb3:
MBR Magic : aa55
Partition[0] : 4294967295 sectors at 4294967295 (type ff)
Partition[1] : 4294967295 sectors at 4294967295 (type ff)
Partition[2] : 4294967295 sectors at 4294967295 (type ff)
Partition[3] : 2559274239 sectors at 4294967295 (type ff)
Remove the USB disk, to prevent mistakes, reboot the nas. Login over ssh, and execute
su
dd if=/dev/zero of=/dev/sda bs=16M count=1
dd if=/dev/zero of=/dev/sdb bs=16M count=1
reboot
This overwrites the partition tables, and after a reboot the disks will be seen as empty and new.
su
reboot
Well, it seems I shouted too soon...
When it's going to recreate the RAID1it gets stuck at 99% with message:Processing,please wait.Creating the 1st volume
Then the unit starts beeping like crazy...0 -
Afaik there are 3 reasons for the box to beep:
- Overheating
- No feedback that the fan is running
- A degraded array
So my guess is that one of the disks has a bad part, and the raid manager dropped that disk as soon as that part was accessed. Your problem started when you exchanged a disk. Why did you do that?0 -
I added new disks to upgrade from 2TB to 8TB...
It's not overheating, the fan is running (from time to time) so it's the array.
It starts beeping after the raid creation is at 99%.
I wonder, can the failed attempts have "messed" up the disks/disk somehow?
It brand new disks...
Is it possible the complete "reset" the disks to "new" again?0 -
I wonder, can the failed attempts have "messed" up the disks/disk somehow?No. Your attempts only have written data to the disks. That is what disks are made for.It brand new disks...That doesn't say much. A brand new disk has a bigger chance to die in the first few hours than a month old disk (which already survived that first hours). Have a look at the SMART values.Is it possible the complete "reset" the disks to "new" again?No. Yes. A new disk is filled with zero's, and it's possible to write zero's to the disk.dd if=/dev/zero of=/dev/sda bs=16MThat will take a long time (it writes maybe 100MB/sec. Do the math), and it won't actually do something, as the OS doesn't read it. When the partition table is empty, it simply assumes the content of the disk is bogus.On the other hand, when the write (after several hours) fails in an I/O error, you know for sure the disk is unreliable.
Mijzelf, your help is very much appreciated!
I've tried to get it running again and swapped places on the disks but it's still the same, it gets stuck at 99% and it starts beeping.
I'd guess it's one of the diska then that is bad... Is it possible to run a "disk check" somehow without the very time-consuming "zero rewrite" that you'd happen to know about?
(The math tells me it's about 23 hours to "zero rewrite the disk, and I assume I have to do that one disk at the time)0 -
You can do two disks at the same time. Just open a 2nd terminal. I think the throughput per disk will be lower, but not half.Is it possible to run a "disk check" somehowI already mentioned SMART. That should be available in the webinterface, and tells you how the disk itself thinks about it's own health.
(The math tells me it's about 23 hours to "zero rewrite the disk, and I assume I have to do that disk by disk...)0 -
@Mijzelf thanks for all the help! I learned a lot but in the end it turns out it's the Zyxel box that is toast...
I bought a new Synology NAS instead and when setting up the disk in it (the same disks) they where chopped up with a lot of weird partitions. After deleting all partitions and have Synology set them up, the disks run fine and an extensive disk-check in Synology (took 8 hours).0
- 588 USG FLEX H Series
- 477 News and Release
