Volume is down - what to do?
gkovats
Dear All,
After a power failure, my NAS326 did not respond and I could not login on NAS on the web. After a factory reset, a managed to get in, but I got the message that the volume is down. (I got two HDDs, but I used only one.)
Based on what I found in earlier posts, I accessed the NAS via SSH and obtained some information.
Could you please help me interpret what I got? I am a novice.
Is there any way to recover the data?
Thanks,
Gergely
Thanks,
Gergely
Your raid arrays are fine, so I suppose there is a filesystem error in the encapsulated filesystem.The 'not mounted' filesystem is /dev/md3. Try a filesystem check:sue2fsck /dev/md3(BTW, when you are using PuTTY for ssh, you can simply select the text with your mouse. Selected text is on the clipboard.)0
Thank you, Mijzelf!
I run the commands you suggested and got the following response:
~ # e2fsck /dev/md3e2fsck 1.42.12 (29-Aug-2014)e2fsck: Attempt to read block from filesystem resulted in short read while tryin g to open /dev/md3Could this be a zero-length partition?~ #
Do you have any suggestion?
Gergely0 -
That blockdevice is certainly not zero-length, according to /proc/partitions. Trysudmesg -ce2fsck /dev/md3dmesgThe first 'dmesg -c' will purge the kernel log buffer. The second call to dmesg will show any log messages added as result of e2fsck. I wonder if any I/O errors are logged.
There is a buffer I/O error
"end_request: I/O error, dev sdb, sector 8261800quiet_error: 23 callbacks suppressedBuffer I/O error on device md3, logical block 21"
The result of the last dmesg command follows. Or do you need the result of the first one as well?~ # e2fsck /dev/md3e2fsck 1.42.12 (29-Aug-2014)e2fsck: Attempt to read block from filesystem resulted in short read while trying to open /dev/md 3Could this be a zero-length partition?
~ # dmesgata2.00: exception Emask 0x0 SAct 0x3 SErr 0x0 action 0x0ata2.00: irq_stat 0x40000008ata2.00: failed command: READ FPDMA QUEUEData2.00: cmd 60/00:08:a0:10:7e/01:00:00:00:00/40 tag 1 ncq 131072 inres 41/40:00:a8:10:7e/00:00:00:00:00/00 Emask 0x409 (media error) <F>ata2.00: status: { DRDY ERR }ata2.00: error: { UNC }ata2.00: configured for UDMA/133sd 1:0:0:0: [sdb] Unhandled sense codesd 1:0:0:0: [sdb]Result: hostbyte=0x00 driverbyte=0x08sd 1:0:0:0: [sdb]Sense Key : 0x3 [current] [descriptor]Descriptor sense data with sense descriptors (in hex):72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 0000 7e 10 a8sd 1:0:0:0: [sdb]ASC=0x11 ASCQ=0x4sd 1:0:0:0: [sdb] CDB:cdb[0]=0x88: 88 00 00 00 00 00 00 7e 10 a0 00 00 01 00 00 00end_request: I/O error, dev sdb, sector 8261800Buffer I/O error on device md3, logical block 21Buffer I/O error on device md3, logical block 22Buffer I/O error on device md3, logical block 23Buffer I/O error on device md3, logical block 24Buffer I/O error on device md3, logical block 25Buffer I/O error on device md3, logical block 26Buffer I/O error on device md3, logical block 27Buffer I/O error on device md3, logical block 28Buffer I/O error on device md3, logical block 29ata2: EH completeata2.00: exception Emask 0x0 SAct 0x3 SErr 0x0 action 0x0ata2.00: irq_stat 0x40000008ata2.00: failed command: READ FPDMA QUEUEData2.00: cmd 60/08:08:a8:10:7e/00:00:00:00:00/40 tag 1 ncq 4096 inres 41/40:00:a8:10:7e/00:00:00:00:00/00 Emask 0x409 (media error) <F>ata2.00: status: { DRDY ERR }ata2.00: error: { UNC }ata2.00: configured for UDMA/133sd 1:0:0:0: [sdb] Unhandled sense codesd 1:0:0:0: [sdb]Result: hostbyte=0x00 driverbyte=0x08sd 1:0:0:0: [sdb]Sense Key : 0x3 [current] [descriptor]Descriptor sense data with sense descriptors (in hex):72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 0000 7e 10 a8sd 1:0:0:0: [sdb]ASC=0x11 ASCQ=0x4sd 1:0:0:0: [sdb] CDB:cdb[0]=0x88: 88 00 00 00 00 00 00 7e 10 a8 00 00 00 08 00 00end_request: I/O error, dev sdb, sector 8261800ata2: EH completeata2.00: exception Emask 0x0 SAct 0x2 SErr 0x0 action 0x0ata2.00: irq_stat 0x40000008ata2.00: failed command: READ FPDMA QUEUEData2.00: cmd 60/08:08:a8:10:7e/00:00:00:00:00/40 tag 1 ncq 4096 inres 41/40:00:a8:10:7e/00:00:00:00:00/00 Emask 0x409 (media error) <F>ata2.00: status: { DRDY ERR }ata2.00: error: { UNC }ata2.00: configured for UDMA/133sd 1:0:0:0: [sdb] Unhandled sense codesd 1:0:0:0: [sdb]Result: hostbyte=0x00 driverbyte=0x08sd 1:0:0:0: [sdb]Sense Key : 0x3 [current] [descriptor]Descriptor sense data with sense descriptors (in hex):72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 0000 7e 10 a8sd 1:0:0:0: [sdb]ASC=0x11 ASCQ=0x4sd 1:0:0:0: [sdb] CDB:cdb[0]=0x88: 88 00 00 00 00 00 00 7e 10 a8 00 00 00 08 00 00end_request: I/O error, dev sdb, sector 8261800quiet_error: 23 callbacks suppressedBuffer I/O error on device md3, logical block 21ata2: EH completeThanks,
Gergely
It's a hardware error.res 41/40:00:a8:10:7e/00:00:00:00:00/00 Emask 0x409 (media error) <F>For some reason the disk cannot provide blocks 21~29 of md3. (And possibly others neither, but e2fsck didn't try further). So for practical use that disk is dead.Do you have valuable and unreplaceable data on that disk?0
Some of it. Family photos and videos.
is there any chance to recover at least part of them?
Do you have any suggestions?
Might Photorec work?0 -
Yes, PhotoRec might work.Basically you have 4 options:
- Try to recover the filesystem.
- Try to recover the files.
- Outsource the recovery.
- Bin it.
On 1: It is possible that the filesystem is still more or less OK. e2fsck (and probably mount) didn't look further than block 21~29, because it was unreadable, and they assumed the volume was no bigger. When you create a bit-by-bit copy of the disk using something like [url=https://www.gnu.org/software/ddrescue/]ddrescue[/url], the copy will at least lack block 21~29 (which means they will contain zeros), but there is a chance that e2fsck will be able to repair the filesystem.On 2: Any tool which can recover files without help of the filesystem, and without choking in I/O errors, might recover some files. PhotoRec is one of them.On 3: That will cost you at least a few 100 Euros, or the equivalent in your local valuta, without guarantee that it will give something. As far as I know there is no 'no cure no pay' in this business.
Thank you, Mijzelf!
I truly appreciate your help.
I just checked the documentation of ddrescue. It is written there that "Never try to repair a file system on a drive with I/O errors; you will probably lose even more data."
My understanding is that the HDD has an I/O problem. Could an attempt to recover the filesystem lead to additional data loss? Or am I misunderstanding something?
Many thanks,
Gergely0 -
Yes. Although any decent filesystem repair tool will cease action on the first I/O error. That's where ddrescue is for. You copy the disk to another one, which doesn't have I/O errors. (I/O errors are hardware errors. The copy will have zero's at the place where the original had I/O errors, but that sectors are at least normal accessible)
Thank you, Mijzelf. I see what can I do.0
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 354 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
