USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
Hi, I'm having very similar unstable wifi issues with my usg20w-vpn much like the OP. Is it possible to get access to this firmware as well?
Thanks0 -
Thanks a bunch Stanley, hope this works
Hi Stanley,
Is it normal to encounter the message:"Ajax communication failed" - after the firmware upload has been completed?
I encountered that error, and re-uploaded the firmware again (just in case)...but the same message came up.
Checking the firmware management page does show the firmware running as the one you sent, but unlike the OP, mine does not say USG60W - is this the exact firmware that he received? Thanks again!0 -
Hi, I'm having same wifi issues with usg20w-vpn. Is it possible to get access to this firmware as well?
I'm having similar problem after some days pwd seems not be valid anymore.
When will you release the new official patched firmware?
Thanks nIc
Could I also have it? My USG20W is only 7 days old, running latest firmware, and wireless is non-responsive to changes.0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
