5G NR5101 - Use as 5G Modem
beatus
I want to use NR 5101 as a 5G Modem (DHCP and WiFi are off).
all routing activities (incl. DHCP and WiFi) are done by Asus ZenWiFI router (10.0.0.1).
LAN IP of NR5101 is configured to 10.0.0.2
I'm using 10.0.0.0 network as my local IP range.
If 5101 is configured in "IP Passthrough / Bridge Mode" it's working correct,
BUT it's Web-GUI is not accessible anymore thru LAN.
If 5101 is configured in Router-Mode, there is NO Internet on LAN ports.
Any hints what is the correct configuration to bring it to work as 5G Modem WITH local Web-GUI access?
Yes I experienced this problem too...
The GUI is only accessible over WiFi when in Bridge mode. You cannot access it via Ethernet at all!0 -
I don't know with IP Passthrough but in bridge or single-user mode only one device can be connected. If you want to access the configuration of the modem in bridge mode you have to connect an ethernet cable to the LAN1 port of the modem, which is the one used for bridge mode, the same if you want to put a second device acting as a router.
Buonasera
io uso il mio NR5101 ip di default 192.168.1.1 collegato ad un Asus RT-AX86U ho impostato WAN connessione a internet ip automatico, la connessione a internet e primaria la WAN ip LAN ho inserito 182.168.2.1 - subnetmask 255.255.255.0 ho attivato IP Passthrough dinamico ho provato la configurazione Fisso e ho inserito il MAC del mio Asus ma ho riscontrato che di disconnette spesso e non si riconnette devo spegnere e riaccendere il router o staccare il cavo dalla porta LAN/WAN non so come mai dovrebbe essere più stabile inserendo il MAC del dispositivo ho provato a lasciare il server DHCP attivo o no ma non cambia nulla la differenza e che collegandosi al wi-fi del NR5101 con DHCP attivo assegna ip del dispositivo e ip router automaticamente e le app per telefonini si avvinò automaticamente se non è attivo il server DHCP con la app prima di connettersi si deve indicare ip del router e la porta 443 o in alternativa inserire manualmente gli indirizzi sulla rete sul proprio telefono comunque connesso al wi-fi del Asus a altri Router collegati alla rete raggiungo da web GUI del mio NR 5101 se non ricordo male anche tramite servizio openVPN impostazioni di Asus raggiungo il mio zyxel nr5101 e anche con i servizi DNS Dynamico noip o quello offerto da Asus se la sim e DENAT
Ciao Gianluca spero che sia di aiuto la mia esperienza0
- 3K Nebula
- 222 Nebula Ideas
- 620 USG FLEX H Series
- 350 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
