Low connection Speed on NWA50
Polytox
Polytox Posts: 3
Friend Collector Fourth Anniversary
image  Freshman Member
edited November 2023 in Nebula
I recently purchased a NWA50 for testing purposes. I planned to install 3 APs in my house to have wifi all over.
Now I encounter the problem that the NWA50 only assigns my mobile with 96mbps to the 5Ghz WiFi.
I changed cable.
I connected an other APs (not zyxel) to the same cable and got assigned 400mbps.
Why is the NWA50 only giving me such a low speed?
Distance is directly in Front with 1-5 meteres. Value stays the same.
i set up the ap as low density in nebula.
Any ideas?
  • Zyxel_Bella
    Zyxel_Bella Posts: 596
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    image  Zyxel Employee
    Hi @Polytox
    Welcome to Zyxel Community!
    There are many factors impact the result such as environment, connection quality …
    Ensure your AP and wireless clients are all upgrade to latest driver version and follow the pdf file in the article to setup/check the environment.
    https://community.zyxel.com/en/discussion/13088
    If the performance still not as expectation, please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, save the changes for us to check. And provide the Org and Site name, thank you.
    Regards,
    Bella
  • Polytox
    Polytox Posts: 3
    Hi Bella,
    Thanks for your reply. I checked the guide. Problem still existing.
    I will send you Site/Org Name.
  • Peppino
    Peppino Posts: 186
    First Comment Friend Collector Eighth Anniversary
    image  Master Member
    edited May 2022
    Polytox said:
    Hi Bella,
    These APs are designed to be installed on the ceiling, so if you are not using them like that, it might give you a false reading.
    Also a big mistake is to leave the AP radio power on default values.
    What I suggest to do is to start with a relatively low value (eg. 5-6 dBm) for the 2,5GHz band, and set the 5 GHz radio to about 5-6 dBm more, in this case that would mean 11 dBm. If the area covered will be too small, you can gradually go up by 1-1 dBm.
    THis ensures you have a similar, but rather a slightly higher coverage on 5 GHz, so your clients will be more likely to associate to this radio, thus their connection rate will always be better.
  • Polytox
    Polytox Posts: 3
    @Peppino it's installed in the ceiling. It Was the AP not using 80MHZ when dfs active. Bella again pushed the settings again and it Was working. For now I disabled dfs usage.
Nebula Tips & Tricks
