Nebula WiFi Guest Network has no Internet
i've a guest vlan22 and a ssid associated with vlan22. However, when I enable Layer 2 isolation, no client has access to the Internet, even if I enter my MAC address of the USG Flex 200 in the Layer 2 isolation list.
When I turn off Layer2 isolation, everything works normally. What am I doing wrong? I have 2 Zyxel NWA110AX Access Points and a USG Flex 200 as router/firewall in nebula.
//EDIT: Between access points and usg flex 200 is a HP 1820-48G Switch J9981A. Adding the mac address of the switch does not fix it.
//EDIT2: No security policy rules are set.
Thanks!
Thanks!
Probably the MAC you entered isn’t the actual gateway MAC address of the vlan22.
you can try to type “arp -a” on the cmd of the windows laptop, then check what’s the actual MAC of its gateway, and type it in list.0
you can try to type “arp -a” on the cmd of the windows laptop, then check what’s the actual MAC of its gateway, and type it in list.0 -
Thank you @Greenlight that fixed it! All vlans have the same mac address, but it is different from the device mac address.
- 244 Nebula Ideas
- 6.9K Security
- 809 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
